I need help with error messeges, and 3D.....Anyone? Please?!
I am trying to look at my project in 3d and I keep getting an error messege about my railings and baulisters, so I went and deleted them. but i am still getting it.
Is there a purge/audit command, or a way to fix a problem throgh the program if you dont know what it is?
When i look in 3D, some times it doesnt show everything, and sometimes I get this big black area either in part of the window or in the whole window.
and you kow, of course this is happening when I need to get the drawing out the door today.
Any help? Please, I am drowning here.
jess
You must check library objects.
You must find out your objects.
And than reloade it.
Aussie John
use your Marquee tool to try an isolate where the problem is
Cheers John
[/size]
