JGoode
Image Fill Help Required Please!
I am having some issues with my image fill poly2_b{5}'s. In the image, the picture on the left shows an example of how every preview of the object looks. The image on the right shows how the object is intended to look including the image fill.
Here is the definition of the image fill:
define image_fill 'red' "Red_Image_Fill",
        255, 255, 255, 255, 255, 255, 255, 255,
        0.001, 0.001, 0, 0
Here is the code with it being used:
		FILL "red"
		poly2_b{5}      12,      3,      0,      3,     20,    20,
						   0,            0,            1,            0,            0,            1,            0,
				0.003011396909279, -0.012,      0,
				0.008011396909279, -0.012,    900,
						   0,          180,   4000,
						   0,          180,   4000,
				0.003011396909279, -0.012,     -1,
				0.01201139690928, -0.012,      0,
						   0,         -180,   4000,
						   0,         -180,   4000,
		FILL "red"
		poly2_b{5}       7,      3,      0,      3,     20,    20,
				0.004365269360967, -0.01497020610398,      0,
				0.007369079672544, -0.0126431290699,    900,
						   0, 14.79244119691,   4000,
				0.01167139690928, -0.009047580068978,      0,
				0.00858285669353, -0.01142894928346,    900,
						   0, 14.41018743141,   4000,
It has both the foreground showing in the preview as well as dashed lines running horizontal.
Any help would be appreciated. If you are able to point out any errors in my scrip I'd be grateful.
ArchiCAD 27
Windows 10
4 Replies 4
JGoode
Here is the Element Attributes Fill Types settings for the image fill
ArchiCAD 27
Windows 10
JGoode
Found out the cause of the horizontal lines! The issue now is just getting the image fill to show up in preview and when scheduling.
ArchiCAD 27
Windows 10
runxel
Then please share so everybody can profit 😉
JGoode
It was actually just in the Model View Options, it happens when you override the Fill Background Colour in the fill display settings. Very simple, but I just didn't work it out.
ArchiCAD 27
Windows 10
