Streamline your workflows and master BIM coordination! Program starts April 28.!
Images in library container files
we've made an object, that uses images for its interface. it is all working fine. but when we save the completed package as a library container file and load it into a project, one of the images in the interface doesn't appear. yet if we load it just as a folder with the object & images (what the container was made from) it loads fine.
anyone struck this before?
5 REPLIES 5
Frank Beister
What kind of image, which format. Have you tried alternative formats or other compressions?
I have e.g. mentioned, that you can't save TIF with alpha channel into GSM-Files directly from AC, but by the xml converter.
i've tried it with both tiff & png. they work fine, until I save them into a library container?
Any characters in the file name that are not alpha-numeric or basic things like dash or underscore?
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
the image had an underscore in the name.... although that shouldn't matter, should it?
the only difference I can see is that the working one was a .jpg & the non working one I tried with .tif & .png (because I wanted the alpha channel).
No. Shouldn't matter.
As Frank asked: what file format is the image? How big is it, both in size and in pixel dimensions? Etc?
