Importing Kolbe Windows & Doors into ArchiCAD
How might this information about using Kolbe windows in Revit and Sketchup translate into ArchiCAD.
http://www.kolbe-kolbe.com/gallery/index.cfm?pcID=5&pID=33#tutwq
rgarand
I only have experience with bringing in objects/files from sketchup. When you bring them in they are an UNeditable object with random points to pick on that object. Not parametric at all and with many faces in some instances.
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
Then how do you import objects/files from sketchup into archicad ?
