Impossible to edit a label
Elodie_ER
I'm really hoping for some help because I'm completely stuck.
For the past 10 minutes, I haven't been able to create simple symmetry on my label in layout mode.
I can't move or rotate it.
I cant edit the text too.
It seems like all my "shortcuts" are selected as usual, as are my anchor points.
I've restarted my computer, but nothing works.
I haven't tried it on another file.
Thank you very much in advance for your suggestions!
I found this similar article but didn't see any answers...
https://community.graphisoft.com/t5/Documentation/Not-able-to-edit-text-or-text-labables/td-p/272295
Élodie / Archicad 25 / Windows / PC
Système d'exploitation utilisé : Windows Archicad 25
Operating system used: Windows Archicad 25
Diseno14
Try disabling the grid snap.
Lpalma
Diseno14
Lpalma
Thaaaank youuuu! It was so simple 😆😅 !
Setup info provided by author
