2008-07-11
12:28 AM
2023-05-26
12:21 PM
Rubia Torres
2008-07-11 01:57 PM
2008-07-11 04:05 PM
mc0m wrote:in addition to David's tip, you could also try using your original label and setting it 0.1 degree off the cardinal points. This has worked for me in the past.
I have attempted to use 2 types of labels (Window Marker triangle and Ident Device Ind). In both cases, I cannot get the triangle and text to point upside down.
2008-07-11 11:16 PM
2008-07-11 11:20 PM
mc0m wrote:Try clicking (or unclicking) the
one thing I don't understand is that I have the text size set in this label to be 2. However, it's much larger than the text in another object with a text setting of 5.
