Inlaid cabinet door in Archicad 17
Hi!
Anybody knows how do you show in archicad 17 cabinet wit inlaid panel?
Thanks
3 Replies 3
Can you clarify? If you use an inlaid panel door, it will show up in section/elevation/3D etc.
What is not working for you?
Hi!
Thanks for answer Karl, but I think you can see it even in the Interior Elevation like the cabinet there are in the 3D Smart Part of: D3 Real Kitchen+Bath from: www.ddgi.com.
I don't have a problem with normal cabinets and custom doors... so if for some reason inlays do not show in the 3D Smart Part objects... you should get in touch with Neil McCann (spelling?) ... as only he, or someone who has purchased his library, can answer your question. 😉
