Sefa Yakut
Archicad 29 Kitchen Cabinets vs Archicad 28 Kitchen Cabinets. Why?
It was said that improvements had been made to kitchen objects in Archicad 29.
When I added a kitchen cabinet to the project I was working on in Archicad 29, I noticed that the handles were in the wrong position. When I went into the handle position settings, I saw that the distances here were completely wrong. The same problem occurs when I open the file without using any workspace.
However, when I added the same kitchen cabinet in Archicad 28 without making any adjustments, I observed that there were no issues. I didn't even need to change a single setting for the handles.
Why?
10 Replies 10
Aaron Bourgoin
I didn't work in 28, but yes, in 29. there seems to be some frustrating parameter defaults. And cumbersome adjustments to fix them.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
Lingwisyer
Guru
Could you import the Mapping Table file from AC28? Unless the actual parameters have changed, it should work.
Ling.
ps. I cannot find the toolbar that it is on by default and the documentation for it doesn't actually tell you which toolbar... You can manually add it by searching for Mapping Table for menu customisation.
rm
Why should we have to do that instead of Graphisoft doing their job and giving us library parts that work properly version to version. For those of you who like or have time to adjust code to make parts work, good on you. But most of us need to just get our work done.
Robert Mariani
MARIANI design studio, PLLC
Architecture / Architectural Photography
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
Lingwisyer
Guru
The Mapping Table was for companies to be able to set the defaults across the the entire GS library. I modified a whole lof of materials and default sizes in it for AC28, and that has all come across into AC29, so far as I have noticed, so I suspect that the AC29 object is new and someone failed to match all of the parameters... so reimporting the Mapping Table will probably not help...
Ling.
ps. Should not have to, but it was just a stop gap workaround suggestion as to not have to modify that setting every time you changed to that object...
Karel Landa
I've reported this problem in Technology preview.
In AC29, the logic for handles settings and as well bottom "legs" was chnaged to be better in terms of changing size of the whole cabinet.
As already mentioned, this is just that someone set wrong default number so it looks like this.
Do you have the last library update for Archicad 29?
From Archicad 17
MacBook Pro M1 Max
Aaron Bourgoin
I've attempted to update my Archicad Library a few times now (AC tells me there is an available update), but the Installer app says it's already updated and refuses to execute. Based on the illustrations on this post, I'd say my cabinetry is not up to date.
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
Eduardo Rolon
I've heard that there might be a bug with the auto-update so I would recommend download directly and then install.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Aaron Bourgoin
Hi Eduardo, I attempted a manual install: 3 times with three different downloads.
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
Eduardo Rolon
Uff… Wild try, if AC28 installed rename the Library Package folder and then try again?
AC29 US/INT -> AC08
