Find the perfect object, manage libraries, create custom objects
Instantiate a 3rd party object into an own "Layout object"
Hi.
This is my first GDL script.
I am trying to instantiate a Toilet, Bidet, and Shower into a "Badroom Layout" Object.
I want to invoque already created Toilets, Shower and stuff into the Layout object.
Do you know what is the function name?
Thanks in advance !!
4 REPLIES 4
Weird of GDL to have called "Macro" to an "Object" or "Class"
macroToilet = "WC 20"
CALL macroToilet PARAMETERS      ! use parameter default values
CALL "leg" 2, , 5  !!!!! A = 2, B = 0, C = 5
This is for historic (legacy) reason.
A long time ago GDL macros were not GDL Objects. They were simply 2D, 3D, etc. GDL scripts and a GDL macro file had the *.GDL extension.
Then a new capability came in GDL, which was that you could now call another GDL Object (*.GSM extension) as a macro. If you called it from the Master Script, the Master Script of the macro was called; if you called it from the 3D Script, the 3D Script of the macro was called, and so on.
But the GDL syntax remained, only its capabilities were extended.
So that is why this seems a bit strange now.
Thanks laszlonagy !!
Any Hint to have a Parameter defining a Macro?
I mean, one thing about classes is that the keep the properties naming and structures.
In GDL, once I CALL a Macro I don't have access from properties to setup the called Macro. As much as I looked, I found most GDL code setting all up with duplicated parameters.
jacobidiego wrote:
...In GDL, once I CALL a Macro I don't have access from properties to setup the called Macro. As much as I looked, I found most GDL code setting all up with duplicated parameters.
Maybe about it:
CALL "leg" PARAMETERS A=2, B=0, ZZYZX=ZZYZX, alpha=Param_1, beta=Param_2, gs_cont_pen=Param_3, gs_detlevel_3D=gs_detlevel_3D, gs_resol=gs_resol -!!!- All the necessary parameters
Param_1 etc - The parameters of your element, controlling the macro parameters.
