Find the perfect object, manage libraries, create custom objects
Interactive Schedule -
I would like to create a list of furniture (objects) for a project based on the rooms (zones) they are contained in.
Using the Interactive schedule a basic summary list is possible, but by zones it does not appear possible.
Looking at the calculate list option it looks equally impossible(?). Is this right, or can a library part detect what zone it is in?!
Project deadlines loom as always - any suggestions would be greatfully received.....
2 REPLIES 2
Click Zone Name in the list of General Fields - drag this field to the top of your field list and set it as a subtitle (grouping) field... if your filters and other fields are correct, you'll then get a list of furniture by zone.
HTH,
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks Karl
Silly me - I had scrolled down to the zone heading under Available parameters rather than look under 'General' subheading!
Very useful.
