Is there a way to make the door appear in to from zone?
LeeJaeYoung
Archicad seems to be possible only when the edge of the zome and the wall are in contact.
A door will only come out if the zone area contains a wall.
End of test ^^
AC27 on window 11
11 REPLIES 11
I am not sure I understand your problem then.
I just showed you a zone placed in a room will pick up the doors and windows placed in those walls.
this is section
this is plan
If I could make a door like this, my problem would be solved. Is it possible?
AC27 on window 11
