Is there a way to see the changes brought to an object in real time?
Say, if i placed a tree and go into the object selection settings to change its properties. Is there a way to see these changes before I click on OK all the time??
Hello Hishiiro,
You can preview your object at the top right of the parameter window. You have a plan view, an elevation view and an axonometric view.
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
Hello Hishiiro,
Christophe - FRANCE
Christophe wrote:
Hello Hishiiro,
Ah. I didnt know i could change that view. Thank you.
