Is this in order?
In an Archicad file that is set up in millimeters,
GLD script (codes) values should be written in millileters
parameter table values should be entered in millimeters too
kindly confirm or correct
Thank U in advance
Femi
In GLD script must always be used meters.
In Parameters Window, showing the value according to the Working Environment.
David Maudlin
It is possible to use English units in a GDL script, but they will be translated to metric units for the calculations.
This is generally true.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
I got that
Thanks a million for the contributions
