Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
SOLVED!
Issue with Project2{4}
Nader Belal
Mentor
Hi there,
I have found a special case issue related to the use of "Project2{4}" that needs to be reported ... where should I comment it to the developing team of Graphisoft ?
Thank you in advance
A good friend of mine have once told me that I“m so brute that I“m capable of creating a GDL script capable of creating GDLs.
1 ACCEPTED SOLUTION
Solution
The best place is to contact your local Graphisoft support centre.
There is also the GDLCenter forum (link at the top of this page) but there is no guarantee that Graphisoft will pick up on it there.
But it is a good place to discuss the problem.
2 REPLIES 2
Solution
Nader Belal
Mentor
Thank you @Barry.
