James Murray's Slab Label
I am having troubles getting this object to work. Anyone that has used this with success, I could really use your help.
I have downloaded the part from the Depository. I click the label tool, and set to read the bottom of the slab, but all I get is a "0"" reading, and the level dimension still hasn't been updated by GS to read the bottom of the slab/roof for a RCP.
I thought that maybe the gravity setting had something to do with it, but it is grayed out.
Thanks for everyone's help!
2 REPLIES 2
It needs to be an associative label for it to work. You need to select the slab, go to the listing and labeling section, then tick 'label slab'.
It will then automatically place the default label for that type of element.
Hope that helps!
Thanks Peter!
I figured it was something simple.
