Aussie John
Labels have stopped working
Since upgrading my labels no longer working.
If an element has already been labeled i can still see it but if I reapply it it disappears. The hotspots are visible but not the ID text. Is there something about v9 label scripting that has changed?
Edit:situation normal - user error!!!
Cheers John
[/size]
4 Replies 4
Did you ever find out how to make them work? I have noticed the same problem.
has anyone else had problems with labels (lost leader lines) in 9?
No
Depending on the label you are using, sometimes you need to go in to the "Symbol Label" area of the dialogue box and click on or off on the "Use Symbol Arrow" box.
HTH
Dan K
