Lattice Object
Srinivas
Hi All,
I am working on a remodel project that needs the attached lattice object to be modeled, can any one has an object/suggestion that makes it little easier for modeling. Thank you for you time.
-Srinivas
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
9 REPLIES 9
vistasp
Does this trellis object by Erich work for you?
http://archicad-talk.graphisoft.com/viewtopic.php?p=167746
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Srinivas
Thanks Vistap, I did a quick testing, but it didn't work out for me, thank you for your time.
ArchiCAD Service
Mac, Windows 11
vistasp
Oops! Sorry, wrong object.
How about the lattices here: http://archilib.od.pagesperso-orange.fr/
= v i s t a s p =
bT Square Peg
Srinivas
Thanks again, I had that object, but it doesn't work in this case for me.
ArchiCAD Service
Mac, Windows 11
vistasp
Not for the upper part but for the lower one.
= v i s t a s p =
bT Square Peg
Srinivas
Thanks again, I was looking to get the upper part working, but I found an object that works for the upper part, can you please post the screenshot on how you got the lower part working with the Treillages object, I had, I haven't been able to get rid of one of the inclined timber.
ArchiCAD Service
Mac, Windows 11
Srinivas
Just edited the GDL object, now its working for me thank you, if you can still post the screenshot, I think I will learn something from it. Appreciate all your time.
ArchiCAD Service
Mac, Windows 11
vistasp
A teeny weeny bit of GDL will very easily do the trick.
Edited: You beat me to it but it might help someone else. Just comment out the highlighted part.
= v i s t a s p =
bT Square Peg
Srinivas
yep did the same, just added an operator with an if statement, so that I can turn on/off the double lattice. thanks again.
ArchiCAD Service
Mac, Windows 11
