2020-04-08 11:09 AM
2020-04-13 04:08 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-04-16 03:44 PM
2020-04-29 10:43 PM
Minh Nguyen
GRAPHISOFT
2020-05-01 08:25 AM
2020-05-01 09:48 AM
2020-05-01 10:16 AM
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2020-05-01 11:15 AM
Erwin wrote:Erwin,
Scott, while I also can't see a need for such a huge gap, I'm unaware of the subfloor thickness parameter.
In our projects, typically, there is a cement floor and on top of that we have a 20 mm margin for floor finishes. Most of the doors need a 10 mm gap for ventilation. Since the frame is placed in the 'rough' phase of construction, we need a 10+20=30 mm gap.
I've been using the undercut parameter for this and it is working fine, but the subfloor thing sounds interesting. Could you share a screenshot of where you set the parameter, so I can try to look for it in our local library version?
For Benjamin: if you need a door with a huge gap, perhaps it is also possible to script a leaf which has a gap.
2020-05-01 12:37 PM
2020-05-01 01:42 PM
