2006-01-27
09:39 AM
2023-05-24
12:09 PM
Rubia Torres
2006-01-27 04:44 PM
Seiss wrote:Sounds like what you're looking for is more of the process of placing a fireplace. The "proper" way to place the object is by placing a door/window in the wall in order to create the opening. It would be great if the fireplace would create its own opening in the wall, but I think the way to do that would be to either save it as a door/window or SEO it from the wall with a downward extrusion once placed (if modeled appropriately).
What is the proper object / preference setting that allows the firebox opening of a fireplace to show in the 3D window. The fireplaces in the library cut the wall just fine in the 2D plan, but not when seen in the 3D window the fireplace opening is concealed by the wall skin with the hearth sticking out.
2006-01-27 09:40 PM
2006-01-30 12:23 AM
