Library - Change texture path origin
dunamisarch
Hello, I have a file that was first made using a portuguese version and when I open in mine, that is set up in INT some textures are not recognised because they are in portuguese library (when i open the portuguese 27 version it works fine) , and my student license only covers the INT version, so how can I change the textures file path way? as in change the said texture from the portuguese library origin to the english library
1 REPLY 1
scottjm
Do you still have access to the computer that has the Portuguese ac27 installed? If so you can just copy the whole Archicad library and textures library from the installed folder of the Portuguese version of Archicad and copy it to wherever you want.  And then link that location as a linked library into your file.
Setup info provided by author
