Find the perfect object, manage libraries, create custom objects
Library Loading Report - Missing property
I think I added this property object some time ago and now all my archicad files open with this listed as missing. Can anyone advise how to get resolve this missing file/ where to fix it?
1 REPLY 1
Hello,
Some of your tool [wall, object, slab, etc.] might have that property
linked 'Individually' or 'By Criteria' as default -> check thru the toolbox 'Listing and Labeling'.
If it's found there 'Individually' it is hard to get rid of. Even if the link is greyed the library manager gives an error. Better to create a dummy property in your common library and link to that one.
If it's found 'By Criteria' then change those settings (ArchiCAD 11 manual page 329).
Hope this helps.
Juha
