Kacper93
Library Part Maker for Archicad 27 POL
Hi 😉,
I wonder why I can't download LPM to Archicad 27 for the Polish version of the program?
Versions for other countries are available.
1 Solution
DGSketcher
Legend
If you try to change the global setting, underneath each country is listed the "language localisation". In the case of Poland it is shown as English, which is probably why it is pointing at the UKI/INT download. I would suggest it may be worth downloading and trying to install. I assume AC will complain if it isn't compatible.
Go to post
13 Replies 13
As far as I know there is only an INT version for LPM.
I just downloaded it with no problem.
https://graphisoft.com/downloads/addons/lpm/int
Correction.
There is a  version for each language.
The main page for download links can be fond here ... https://graphisoft.com/downloads/addons/lpm
Kacper93
Hi Barry,
Thank you for your answer. So why is the website divided into different versions depending on the country?
Sorry.
Must be the cookies or what ever takes me directly to the INT page which is good for the UKI version.
I see if I play around with the URL I can get to the page you show with all of the language links.
Clicking the POL link, I get the same 'can't find page' error as you.
It seems the URL link is wrong, but I can't work out what it should be.
The 26 link works but if you change the URL to 27 it doesn't.
The other links for 27 work, but again if I try to change the URL to 'pol' instead of 'int', it doesn't work.
I notice the links for each language version are different in format as well.
For example French is ... https://graphisoft.com/fr/downloads/addons/library-part-maker
But Austrian is ... https://graphisoft.com/at/downloads/addons/lpm/aut
Usually you can just play around with the country identifiers, but I can't figure it out for the polish link.
Maybe best to contact your local Archicad Support.
DGSketcher
Legend
@Kacper93 The "Globe" to the left of the [MENU] button doesn't indicate your country e.g. POL. Try setting that and then using the link in the main page. GS do like to abuse the cookies so if they are blocked or incomplete things may not work. I recently had to delete/reset my cookies in order to be able to access material on the Learn portal.
He has that correct - PL = Poland/Polska.
But even when I set that it takes me to the UKI/INT download.
If it is either a cookie or by the VPN, they are both not working for me.
I think it might just be a bad link on the page, because we can see the link, it just doesn't work, but all the others do.
DGSketcher
Legend
Kacper93
I downloaded and installed the English version and it works.
It's just that the language in the palette is English instead of Polish.
Thanks for your help. 😎
Karol Argasinski
Hi there,
I went through the thread and I am not satisfied 😎. Is there an installer for Library Part Maker for AC27 POL? I think it is a bug or bad linking. There is one for AC26...
Someone from Graphisoft, please check the website.
OPENBIM does works!
ArchiCAD 22/23/24/25/26/27/28/29 INT &POL
AMD Ryzen 7 3700X, 128GB RAM, GeForce RTX 3070, Windows 11 Pro
MBP 14 M3 Max 16C/40G, 128GB, 2TB
http://www.bimfaktoria.pl/
mthd
No LPM AUS ? I don’t know why and am not GDL or PARAMO literate. I will just have to wait till it is available and then I might give it a try.
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
