Library Part Maker window help!
JGoode
So I have made a window object and it works fine when placing within the LPM project but when trying to place in a different project it doesn't work. There are errors with the 2D and 3D. I opened the script and checked it and it showed that it couldn't find the object that the script was trying to call. Any help would be much appreciated.
Thanks
ArchiCAD 27
Windows 10
David Maudlin
JGoode:
See this thread: Library Part Maker not transferring parts to other projects.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
JGoode
David wrote:
JGoode:
David
Thank you very much. Solved it!
ArchiCAD 27
Windows 10
