Library problems
I get massive error messages every time i add, or edit a door, i have found some minor threads concerning similar problems but not quite the same. Im running archicad 11 on a macbook pro, and the following errors are what appear.
Fill not found
at line 105 in the 3D script of file wa_trim_us_10.gsm.
Fill not found
at line 251 in the 3D script of file wa_trim_us_10.gsm.
Fill not found
at line 530 in the 3D script of file wa_trim_us_10.gsm.
Fill not found
at line 932 in the 3D script of file wa_trim_us_10.gsm.
Fill not found
at line 1468 in the 3D script of file wa_trim_us_10.gsm.
Fill not found
at line 1669 in the 3D script of file wa_trim_us_10.gsm.
Fill not found
at line 1717 in the 3D script of file wa_trim_us_10.gsm.
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
at line 82 in the 3D script of file da_door_fl_10.gsm.
Fill not found
at line 223 in the 3D script of file da_door_fl_10.gsm.
Fill not found
at line 253 in the 3D script of file da_door_fl_10.gsm.
Fill not found
at line 63 in the 3D script of file da_oplines_10.gsm.
Fill not found
at line 75 in the 3D script of file da_handletyp_all_10.gsm.
Fill not found
There are several problems with this file. You can cancel the operation with Ctrl/Command - period.
Im really stuck as to what to do about this i have tried reinstalling archicad and i am using build 1210 i have also updated to the most recent library, the objects(doors) that i am using are standard ones included in the archicad library, not add ons. thank you for any help you can provide!
10 REPLIES 10
These errors are back!!! Can anyone help?
