David Bearss
Limited ability to drag edit Door Marker
What am i missing here? I have editable hotspots visible and can edit sometimes but mostly getting the annoying error beep. Arrow tool, door tool, some setting I am missing somewhere?
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
3 Replies 3
Hard to say from your description. Are there any more details that might shed some light?
David Bearss
So maybe a bug?
I select the door marker and try to move a hotspot and am unable too. However if I select the move function in the pet pallette and then re- select stretch in the pet pallette, I am able to perform the edit to the door marker. A few extra mouse clicks but it does get the job done.
David Bearss
Alienware 17 R5
Da3dalus
This is still a bug in ArchiCAD 16... we'll have to see about 17. I assume everyone has the problem, since I've seen it on several models on different computers. Easy work around, but annoying if you have to adjust many doors.
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
