‎2010-01-14 04:05 AM
‎2010-01-14 04:26 AM
‎2010-01-14 10:50 AM
for i = 1 to nGridLines
if gridXPosition < 1 then
gridXPosition = 1
endif
if gridXPosition > 5 then
gridXPosition = 5
endif
next i
parameters gridXPosition = gridXPosition
I hope one of these methods will help you.‎2010-01-14 12:54 PM
Unfortunately, there is no way to define values for array type parameters:(
‎2010-01-14 01:17 PM
‎2010-01-14 01:27 PM
‎2010-01-14 02:59 PM
‎2010-01-14 06:52 PM
Olivier wrote:Yes, you can do both.
Hello Zsolt,
by the way I was wondering if there was a way for using dynamic arrays as input parameters.
If I'm not clear:
I can define a dynamic array like this in the script: dim myArray[][]
But if I wanted that myArray to be available as a parameter input (in the UI) then I can't. I have to give its dimensions, and they can't be changed.
Is that right or is there a workaround?Olivier
‎2010-01-15 12:37 PM
You shouldn't put array parameters directly in the parameter list or in the interface anyway.Zsolt,
‎2010-01-15 01:44 PM
