Linked library : ArchiCAD Library 18 Unavailable
Hello!
I`m new in ArchiCAD, just installed the educational free version of the program (ArchiCAD 18 ) and downloaded the files for the Training Series.
I am currently in Vol 2. But I got a problem, when opening the file I get the Library Manager telling me :
Linked libraries:
ArchiCAD Library 18 (Unavailable)
ArchiCAD Migration Libraries (Unavailable)
It seems like I don´t have the standart libraries...could you help me solve this please, there is no way I can keep going and learning with this problem!
Thanks in advance!!
2 Replies 2
Eduardo Rolon
You have the Standard Libraries the problem is that the AC file does not know were they are:
• Select the triangle next to "Añadir"
• Go to "Vincular…"
• Then go to "Applications->Graphisoft->Archicad 18"
• Select one of the missing Libraries there
• Do it again for the next one
That should do it.
read here
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/configuration/libraries/trou...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thanks a lot!!!! It was just that simple, but I had no idea!! 😃
