Loading Libraries
I have a drawing which was started using Archicad Release 7 - and we are now using under Release 9 (by way of 8 and 8.1). At each stage of its evolution, more libraries were added, and eventually someone advised saving the project as a .PLA - which seemed to work okay. The .PLA file (as I understand it) now contains all the library parts which are actually used, and after having opened the .PLA file in order to edit the drawing, it is then saved as a .PLN on each subsequent occasion.
However there are 2 problems:
1 is: each time I open the drawing, I get the following 5 messages:
'Duplicated database name "Roofmaker 2.1" at line 1 of file MASTER_GDLRoofmaker 2.1.gdl.'
'Duplicated database name "AC_9_INT" at line 1 of file MASTER_GDLAC_9_INT.gdl.'
'Duplicated database name "AC 70 Qen" at line 1 of file MASTER_GDLRoofmaker 2.1.gdl.'
'Duplicated database name "Roofmaker 2.1" at line 1 of file MASTER_GDLAC.70 Qen.GDL.'
Is there some way of purging these messages?
The other problem is that sometimes library windows and doors display as blobs, and I have great trouble trying to correct this, even after loading every library on the system.
Ben Odonnell
Check to make sure that you don't have the PLA and the respective libraries(ArchiCAD 7 and or 9) loaded at the same time.
If you do, it will give you an error messages.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
