Mapping issue!
I have created a GDL object with mapping. when I insert the object in the drawing and enlarge it, the mapping gets tiled, which I don't expect to. The mapping should also get scaled with the object. refer the image below!
David Maudlin
Rajesh:
In order to fit the image to the object as it is resized you will need to either:
1. Resize the texture of the material to fit the new size (under Materials...).
2. Use the Picture command in GDL with the correct mask value to fit the texture to the object as the object is resized (see Picture in the GDL Reference Guide).
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
