Roof Surfacer - where'd it go in 11
I loved the Roof Surfacer tool in 10. Where is it now and if I have to buy it (likely) where do I do that?
6 Replies 6
Link
It's a goody. In AC11, you need to download it separately and load it as an add-on. Don't worry - it's free and you should be able to find it via your help menu: Help>ArchiCAD 11 Goodies>Accessories.
Link.
thanks so much!
I downloaded the add-ons but when I go to use them they don't work. Any thoughts?
Did you also install them? They need to either be in the default add-ons folder (typically in the ArchiCAD program folder) or loaded in the Add-on Manager.
Make sure that you download the addon AND the Library.
Djordje
... and install both by placing the AddOn in the AddOns folder, and loading the library in your template, as well as the running projects.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
