Sliding GATES
Need object: Sliding Gate on compound wall and also masonry compound wall...............
plzzzzzzz plzzzzzzzzz help ASAP.
4 Replies 4
What is your problem?
problem is this that i dont have the object in my library and i desperately need it.
I meant, what exactly do you need, could you be more specific? Often there is some objects that would work, even if it don't look like that at first sight.
Djordje
Use the Sliding door from the standard library. If you need a custom door leaf, see the ArchicadWiki for the directions how to create it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
