Marker for section or details
Can I have some Markertypes for section-details?
One side roundfigure and the other something different...
3 Replies 3
David Maudlin
Yes, you can do this with GDL. The object subtype needs to be set to Section Marker (under the Marker category). It will appear as one of the marker options under Marker in the Section/Elevation Tool dialog box.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
If you mean to have different markers at each end, yes there is a way to do it. I did it myself recently to put a flag on the far end of the cut line. I forget the details now but I'll try to look this up later if someone else doesn't beat me to it.
Thank you Mathew.
I have seen this Marker from "Revit".
Revit has such a Marker for Detail Section (or elevatation) Marker.
I have seen in the showing movie from the revit web-site.
This marker is really cool (I dont buy Revit because of Marker.).
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=3781831
From there the subtitle is "better coordination and quality"
See you later
