Material label
Hi..
¿It is possible to make a wall label wich shows the name of material applied to de wall?
If AC can put the names and sizes of the fill, why not the material?
If only some GDL guru could help me...
there is the label that i want (for finish plans).
thanks for any help.
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
1 REPLY 1
Labels can be a bit aggravating to make behave, but what you want is fairly easy to write. One tricky bit will be getting material names to fit into your hexagon. Another is, if you plan to use the actual material settings, you may have to split up a lot of walls where room finishes change.
