Misaligned door
Thanks in advance to anyone who can help with this.
I built this door using the slab tool. The user origin was placed at the center of the bottom rail, but when I use it as a custom panel in D2, it looks as if it has moved halfway through the door frame (like a sliding door). It looks fine in plan, but when projected into 3D it slips to the side of the door frame.
To create a GDL object - do you have to open an entirely new file? Is that the problem?
1 REPLY 1
Erika Epstein
When you create a [custom] panel, it needs to be saved as an object not a door.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
