Missing Accessories Objects
Brett Brown
Can anyone shed any light on why the attached screenshot shows "Missing Roof Accessory Objects" is stated when they are loaded as per GS Support instructions? Same in all 4 accessories where they are loaded and the red text says they are missing.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
4 REPLIES 4
Your 24 accessories are loaded and they are appearing as shown in your image.
Could it be that the missing objects are from an older version and you need to load the migration libraries?
Brett Brown
All migration libraries are loaded. I would have thought if they are missing, why aren't they showing in the Library Manager as Missing Library Parts, which they are not.
This template is from AC 20.
Does the AC 20 Migration Library contain the AC 20 Goodies which was in the AC 20 Addons folder?
I just checked and the version 20 roof accessories migrate automatically to 24 objects so long as the 24 accessories library is loaded.
No need for migration libraries as such.
You missing objects folder is greyed out.
When I have missing objects it shows solid and when I select it it shows the names of the missing objects.
What happens when you select that folder?
Usually if nothing is miss, you will not see that folder at all.
I have never seen it greyed out.
Brett Brown
Thanks Barry for your help, I uninstalled the Goodies and reinstalled them. Still the same. I will just have to live with it. Possibly a bug. I will suggest that to Support.
