Missing Object
I'm want to delete all of the missing objects in my library manager.
Problem is I can't find those objects (the missing dots) to delete them.
I don't use them...
Does someone know how to solve this?
Thx!
Charlotte
5 Replies 5
David Maudlin
Charlotte:
Use Find & Select, set Element Type to Object and add Criteria Library Part and set to Missing. You will need to go though all the Viewpoints as this does not work in the 3D Window.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi David,
Thx for the tip. I've made some changes to my Signature. Hope it works...
I Now have only 1 missing "object" left but it seems to be an attribute. Any idea how to find what is linked to this thing called "Arduin" zo I can dislink it?
Thx!
Charlotte
Erika Epstein
Use the Attribute Manager.
Options>Element Attributes> Attribute Manager.
Activate the tab with the type of attribute you are seeking.
Select it and hit the Delete button. The program will ask you to confirm your actions before you can close the Attribute Manager
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erwin Edel
Hoi Charlotte,
if you view the library loading report palette (the one you posted a screenshot of), and select the missing texture in that report, there is a blue button with 'i' to the right side. If you click that, a popup will show which surface is using the texture. You can delete the surface (assuming it is not being used) in the surfaces dialog. You can allways choose 'delete and replace' to replace it with some other surface.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
David Maudlin
That's good, thanks for adding it, particularly as you are running an earlier version.
