Arcadia
Missing library parts/textures
I am getting a missing library part report everytime I load up ACV12 which is starting to get annoying. If I ignore it makes no difference. It says missing library parts then underneath it says "3 surface textures" then 3 names being "rietveld crate" "rietveld lino" "rietveld zig-zag". Now these seem to be textures or materials not library parts and refer to (I think) a small furntiure object library which I deleted previously and no longer have in my template file in any way. Is there a way I can either get and load these textures - whatever they are. Or just stop AC from checking for missing library parts?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
These will be materials that have been set up to use those textures.
You will either need to delete those materials from your material list or set them to use another texture that is loaded already in your library.
Or find the missing texture images and add them back into your library.
Arcadia
Thanks. The penny has dropped now and I have found the materials that use those textures and deleted the textures. Cheers.
