ā2019-05-17
08:46 AM
ā2023-05-24
12:26 PM
Rubia Torres
ā2019-05-23 08:24 AM
Lingwisyer wrote:
Do not think this will be the case since the 3D preview is generated from the same script as the actual object itself, but, if you go toOpen Object by Subtype, do you have the following object?
General GDL Element => Model Element => Macro => Sash
If not, you will want to reinstall your default AC library.
Ling.
Thank you Ling, I checked and version 36 of the sash is there, I will uninstall AC and reinstall over the weekend and see if that works. I will report back if that works.
ā2019-06-24 10:48 AM
ā2019-06-24 11:07 AM
ā2019-06-24 12:50 PM
ā2019-06-24 01:58 PM
Palawat wrote:Yes, that is what Tiny discovered.
Maybe it's MVO.
Please check your "Model View Options" and make sure that the "3D and Section/Elevation" for window under "DETAIL LEVEL OF DOOR WINDOW..." is set to "Full".
ā2019-06-24 02:06 PM
