Modelling and old window with pointed upper case
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-09-14
06:03 AM
2023-05-26
02:16 PM
Rubia Torres
2016-09-14
06:03 AM
I have an issue, regarding modelling in ArchiCAD 20 - how can I do such a window. I have almost all parameters done, except this upper case of window. Please help.
Best Regards,
Karol
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-09-14 06:20 AM
2016-09-14
06:20 AM
Is it the shape of the window, or just the glazing bars in the upper section that is the problem? Cadimage windows will do a Gothic arch (see below), then I would just model the curved glazing bars as morphs and position them in the window opening.
Of course if you don't have Cadimage tools you could model the entire thing as a Custom window, using slabs (or morphs) for each element, and a slab with the ID of WALLHOLE to cut the opening in the wall.
See also How to create Custom Window
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-09-14 06:23 AM
2016-09-14
06:23 AM
s2art wrote:Thank you for such a quick response!
Is it the shape of the window, or just the glazing bars in the upper section that is the problem? I would probably just model the curved glazing bars as morphs and position them in the window opening.
Of course you could model the entire thing as a Custom window, using slabs (or morphs) for each element, and a slab with the ID of WALLHOLE to cut the opening in the wall.
Both things are problems, but major one is a shape.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-09-14 12:03 PM
2016-09-14
12:03 PM
I assume you are modelling an existing 'as is' situation, I would make a custom library part as suggested. It's not like it will be changing much afterwards, to have need of the benefits of having parametric options.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
