Modifying GDL object
DennisG
Greetings;
I am working with construction containers, and am excited to see that there are four container modules available in the construction components library.
Only one problem: containers come in two lengths, but these objects come in only one (shorter) length.
How can I modify specifically the length of the container object?
Much thanks,
Dennis
Dennis Glynn AIA
ArchiCAD-64 23 3003 USA FULL
x64 Clone PC w/Intel(R) Core i7-4790 CPU @ 3.60GHz, 3601 Mhz, 4 Cores, 8 Logical Processors
NVIDIA Quadro K620
16.00 GB RAM
Win 10 Pro x64 based PC
13 REPLIES 13
Frank Beister
maniac
Nice. In german. But you should rename it, because there's a container.gsm in the AC9 standard lib.
gerd
in german
more or less mixed..., the parameter values are still english, because I had no good mind to change them too (they are spread all over the scripts...).
but it's a good example for your poll here:
Multi-Language database in objects
best regards, gerd
DennisG
Gerd, you are indeed The Man!
Much thanks,
Dennis
Dennis Glynn AIA
NVIDIA Quadro K620
16.00 GB RAM
Bruce
F. wrote:
maniac
That may change country to country, because I don't have a container.gsm in my AC9 standard library
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
