Hey all,
I am trying to make my first gdl lamp object. So far i have created a frame including a simple LIGHT script to produce light. I have saved it as a regular object, but how do i go about saving it as a LAMP object and then getting the lightworks to render it properly? Thanks for the help.
You need to change the subtype (the button for that is at the top of the parameter list) then you need to set the light settings (the syntax is in the GDL Manual, but I would look at some other lamp objects for ideas)
