Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
NEED A BUTCHER COUNTER W/GLASS
Is there a butcher counter out there in GDL HEAVEN that I could buy?
6 REPLIES 6
Dwight
what length do you need?
Dwight Atkinson
need a 24 ft Butcher Counter, right now am using the Prep Table included in the restaurant equipment library on Objects online, but can't find a butcher display case (the actual measurement of the space is 24'8"
Dwight
like this?
Dwight Atkinson
THAT IS EXACTLY THE ONE I WAS LOOKING AT, BUT NOT WHAT I NEED...
need one with glass in front, sliding glass in rear, coolers below, counter above...the old fashioned counter
vfrontiers
If you can draw the SECTION thru it... you can use a COMPLEX WALL to model it... Might have TWO pieces... one for the glass sections and one for some kind of structural rib...
Really, if you can draw the section(s)... I can convert it.. It's a 5min job.
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
You can find some accessories here
