‎2010-06-29 06:48 PM
‎2010-06-30 12:23 AM
‎2010-06-30 12:26 AM
‎2010-06-30 11:59 PM
‎2010-07-01 01:11 PM
‎2010-07-01 03:34 PM
‎2010-07-01 03:47 PM
Matthew wrote:Would you recommend this method much more than using the Google Earth Connections add-on and dropping .skp objects right into ArchiCAD? I ask because we've had to distance ourselves from using the great variety of Google Warehouse because it runs up the polygon face count. I think that runs up the file size and more importantly, affects the timeframe of an Artlantis rendering after exporting into Artlantis. Please correct me if you think that's not true.
If you have SketchUp Pro (which I highly recommend if just for this purpose) you can export as 3DS and ArchiCAD can convert with proper materials and smoothness.
‎2010-07-01 11:17 PM
‎2010-07-02 02:28 AM
Rafal wrote:Rafal, I would be interested in taking a look at your cart object but am using AC12. Can you post the older version? Your site lists it as an AC13 object.
I've found one in my old libraries, object was prepared for version 6.5🙂 (by Tomasz Smus)
Please check here:http://archiformat.blogspot.com/
