Find the perfect object, manage libraries, create custom objects
Need explanation for some Door Settings
Could you explain me what these door settings are used for?
Tollerance
Nominal Size
3 REPLIES 3
__archiben
they are used for setting up the difference between the door unit size and the size of the hole in the wall. the wallhole has to be slightly bigger or the builder wouldn't be able to get the door unit in there, right? those controls allow you to create and dimension a larger hole yet schedule the right door unit size to fit in it.
~/archiben
b e n _ f r o s t
Ben, I thought Opening Oversize did this. So what is the difference?
Yes, I just noticed that also, why?
