Mario Sacco
New Object 3DMD Polyline Fence
Hi
I'm working on a new object I will share with you on Archicad BimComponents. I share here it in the first beta version, so we can try to find some bags or improvements.
The object fence is really only a simple version of a main object most complex. The logic in which the main object works is to generate a 3d editable poly line, base to generate more complex or simple tubes along it, in which I can distribute more simple or complex posts.
I'll will use the main complex object to create single simple objects.
Give me any suggestion and request of any object based on this logic. I will be happy to try to create your personal request.
The last version is here:
https://www.dropbox.com/sh/jjef9nuhpfwh29y/AAAoBmgIsM-p6eHUy_thILn2a?dl=0
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
79 Replies 79
Hmooslechner
https://www.youtube.com/watch?v=JBgY7avNX5Q
To show You the thougts about the interface and more...
(Just pictures are much too less information - a Vid is much better.. )
Hmooslechner
Because it is not possible in GDL to get information from other elements, i made a few steps between with solid-operating-elements -commands to get the nearly perfect backfilling - volume to display in 3D and sections in Archicad.
In my stepped strip-fonundation-element - i implanted an extra volume for the backfilling - to be cut out of the terrain.
https://www.dropbox.com/s/yt98o9arveb0p2v/Eigener%20Polygonzug_m5.pln?dl=0
Take your time to watch my Video carefully to understand the system.
It would be very complex to program the backfilling in a direct usable way - in fact - too complex for me. So i tried this solution that should work well.
Maybe you have other ideas for this problem?
The video will take some time to get uploaded.
https://www.youtube.com/watch?v=QOmcAoJB6zI
Mario Sacco
Here other staff I'm working on.
You'll be able to apply a picture to the panel. The object will automatic adjust the dimension and distortion, based on the slope and dimension of the panel.
Both material and fill will follow the panels dimension/distortion.
Obviously You'll be able to create your personal texture and fill to mach your fence.
Mario Sacco
Other pict and fill
KenMcN
https://www.dropbox.com/s/jlgaqs2e3y4ak0w/3DMD%20Polyline%20Fence.zip?dl=0
I get a message saying "The file you're looking for has been moved or deleted", has it been moved or the name changed perhaps?
Looks amazing, hope it is still available.
Kenny
V25 & 26 (fully patched); Mac Ventura, MacBook Pro M1 Max
Mario Sacco
Kenny
Thank you. The last link is:
https://www.dropbox.com/sh/86y9z3intan2lq3/AACdWNuzn503ZL-jjikiM9q-a?dl=0
KenMcN
https://www.dropbox.com/sh/b2box3yhuv4oeth/AAC8Q_J7VcdACc-pksmcoEzSa?dl=0
Got it, thanks very much.
Kenny
Very good. Thanks mariosmic.
Sorry, there is a minor bug: the material foundation = SIMB_VIEW_PEN
And preferably the completion of posts. Well, at least the ball, pyramid, custom or handrail or without.
RandyC
Hmooslechner link below to your file with translated parameters - might
help someone a little. I agree seems you need to do a lot of coding just to create one movable hotspot - should be able to create macro' gdl "statements" that can be reused in multiple projects. how about color coded hotspots when you have so many to choose from ?
Randy
https://www.dropbox.com/s/fbvjf45lss2bx3v/Fundamentabtreppung%20Polygonzug%20mit%20WD%20und%20Sockel...
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Hmooslechner
Randy - seems that you used some "worktime" to translate! Thank You!!
Do you speak german or did you have to use googletranslate?
If You want - make an upload on bimcomponents with english naming - or should i do this?
