New object from a 90 deg rotation of existing object?
hi
I want to rotate the '1.4 cladding vert 10' from the standard library by 90 deg so that it becomes a new object '1.4 cladding horiz 10'
I'm sure there must be an easy way...
Any hints appreciated.
Adri
Sorry
'Cladding vert 10' should read 'corrugated sheet vert 10'
Anyone know how to tip it over?
Adri
Djordje
First, do this:
Paste
site:archicad-talk.graphisoft.com "3d rotate"
in your browser's search field.
Check the parameters; if the cladding cannot be rotated, "all" you have to do is to add the rotation parameter. To find how, paste into your search field the following:
site:archicad-talk.graphisoft.com "rotx"
Enjoy
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
