No Casing Door in Complex Profile Error
Hi Guys.
I am trying to place a door, I have tried all doors, in my Complex Profile, and have the door show no casing.
Once I tell it I want to show no casing I get an error messege that says
"index value greater than array dimension at line 262 in the master script of file PlasterGeometry.gsm."
I can put - - - - -
As I was writing my question here i was screwing around in Archicad trying to figure what was working and what was not, and I was about to ask what PlasterGeometry.gsm .
In th end I have found that if you get this error messge and you go to your closure and reveal settings change the thickness of the plaster that ArchiCAD defaults for you - or , what I did, is change it to "use wall Finishes"
So- tada.
0 Replies 0
