2026-01-28 03:45 PM
Yesterday, I was trying to send a quick RFI to an architect. I needed to show a simple W shaped column on the drawing; something I’ve done a million times in Archicad.
Using AC29, I opened objects > 05 Metals and instead of finding “05 10 00 Structural Metal framing 27” > then “Steel Columns”, the “W column 27”, I unfortunately found “05 50 00 Metal fabrications” > then “Steel Columns EN”, then a bunch of metric shapes.
Where did the simple to use, steel shapes that are in English (non metric) units go?
Operating system used: Windows 11 25H2
2026-01-29 09:54 AM
Is there a US Steel libpack somewhere maybe? OR you could export the entire AC27 US steel library and import that seperately.
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2026-01-29 05:07 PM
Graphisoft removed them from the default libraries. Not sure why, since there is no replacement for the functionality that they provided.
Grrrr. 😡
They were still available in 28 installs, located in an .lcf called Archicad Legacy Objects USA.lcf.
If you have 28 installed you can link that library into your file.
2026-01-29 07:59 PM
Can you use complex profiles? I still see an international assortment of steel shapes in metric and imperial
2026-01-31 06:36 PM - edited 2026-01-31 06:36 PM
I'll give that a shot and thank you!. I wonder why in the world they would have done that?
2026-01-31 06:37 PM
I've never used complex profiles.....just never needed them.
2026-01-31 06:37 PM
Dunno but I can try that (I think I whacked all my ver 27 installs).
2026-04-23 05:46 PM - last edited on 2026-04-24 06:18 AM by Barry Kelly
Having the same issue! The Archicad Legacy Objects USA.lcf is the 2D detail symbol, NOT the 3D W object (see screenshot of what is missing). Double checked the Archicad USA Template 2, does not have this object. This is a very used object for our structural coordination, way faster than complex profiles, better selection nodes and easily managed (imho).
The only solution I have found is to export the objects from 27 and import them into our embedded library 😕 which means we're just carrying around outdated objects which seems to negate this whole transfer to a global library!!! How can we get the legacy library update to include these disappearing objects OR come out in a library update??
