Non stretchable object
I made an object by importing some 3D design, selecting it and using Save selection as...
My object is created, but it is stretchable, which I don't want. How to prevent that ?
Thanx
You will need to do a bit of script editing.
Open the object and in the Master or Parameter script add the following.
LOCK "A", "B", "ZZYZX"
It works perfectly well. Thanks !
