Wall Composite Label
Is there a way to change the display of the wall composite label. Typically it shows the entire string of information eg. W01 - 10mm Tile / 10mm Billboard / 90mm Stud / 10mm PB. Is it possible to have the wall code display only? Having all of the additional information is useless for labelling plans.
Any help would be great.
Cheers
Running Archicad 20
1 REPLY 1
Palawat
You might want to check out this label.
https://www.indigofigs.com/symbol-label-suit/
Hope this help.
Archicad 28, Windows 10, Corei7 3.4 GHz, 32 GB Ram.
https://www.facebook.com/indigofigs
